How to edit the attribute information of an address
Revision as of 12:35, 23 November 2020 by Rudolf@tygron.nl (talk | contribs) (Rudolf@tygron.nl moved page Edit the attribute information of an address to How to edit the attribute information of an address without leaving a redirect)
How to add an attribute:
- Select the building that you want to edit.
- Go to the right panel and press Attributes.
- Select building or address you want to edit.
- Select the intended attribute and edit as desired.
