How to add rain barrels to your project
Revision as of 13:13, 2 November 2020 by Reijn@tygron.com (talk | contribs)
Editor → Future Design (Ribbon tab) → Actions (Ribbon bar) → The Action Menu to edit (Left panel) → Actions tab (Right panel)
How to add a rain barrel to your project:
  1. Go to the adding the WFS connection to the external GIS application.
  2. Modify the features of the WFS layer. You can modify the vertices of geometries, and the attributes of features.
  3. Ensure the end result is valid. (For example: neighborhoods cannot overlap, and constructions cannot overlap.)
  4. Save the modified layer in the GIS application.
  5. The data will now be updated in the Tygron Platform.
  • When using a WFS endpoint which only displays partial data (such as the ROADS endpoint for constructions), any submitted modification must still be valid across all data. I.e., even if you can't see other constructions in your GIS application, the modified roads are not allowed to intersect with other constructions in the project in the Tygron Platform.
