How to remove an address
Revision as of 12:50, 2 October 2020 by Reijn@tygron.com (talk | contribs) (Created page with "{{Editor location|Buildings}} {{howto|title=add an attribute | Select the building that you want to have an address. | Go to the bottom pannel. | Select the address you want...")
Editor → Current Situation (Ribbon tab) → Buildings (Ribbon bar)
How to add an attribute:
  1. Select the building that you want to have an address.
  2. Go to the bottom pannel.
  3. Select the address you want to remove
  4. Select the Remove botton
  5. A warning pops up and after yes the address wil be removed (Note:this action cannot be undone)
Example of creating an address
