Waterwijzer Module test results
Revision as of 09:39, 31 August 2020 by Rudolf@tygron.nl (talk | contribs) (Created page with "Testing the Waterwijzer Module manually is feasible, as the performed calculations are not spatial. This means for any given location, only the parameters present in that...")
Testing the Waterwijzer Module manually is feasible, as the performed calculations are not spatial. This means for any given location, only the parameters present in that particular location are used to perform a calculation.
Setting up the project
Create a new empty Project with a minimal size. By creating an empty project the state of the 3D world is entirely known. Add the Waterwijzer overlay to the Project. This will perform the actual calculations.
Configuring a testable dataset
Results
