Tag
Revision as of 10:53, 5 August 2020 by Rudolf@tygron.nl (talk | contribs)
Text in Panels can contain special tags that are replaced by the Tygron Platform based on the Project's data, the Session's data, and the context of the Panel, such as the owner or related Items of the Panel. A tag can be placed anywhere in the text of a Panel, and when the content of that Panel is rendered for display to the user, the tag is replaced by the appropriate data. In other words, the tag specifies a specific kind of data, and that data is inserted into the Panel's text in the location of the tag.
General tags
Tag | Effect |
$PROJECT_NAME | Inserts the name of the Project. |
$TOKEN | Inserts the Web Token of the Project's Session |
Web tags
Tag | Effect |
$LIB_CUSTOM | Inserts the name of the custom javascript library, part of the web interface configuration. |
Contextual tags
Tag | Effect |
$NAME | Inserts the name of the Panel. |
$ID | Inserts the ID of the Panel. |
$STAKEHOLDER_ID | Inserts the ID of the user's Stakeholder. |
$STAKEHOLDER | Inserts the name of the user's Stakeholder. |
Attributes tags
Tag | Effect |
$ATTRIBUTE_ATTRIBUTENAME, where ATTRIBUTENAME is the name of the Attribute | Inserts the values of Attributes stored in this Panel, which can change based on calculations of Indicators or other Panels. |
$GLOBAL_GLOBALNAME, where GLOBALNAME is the name of the Global | Inserts the values of Globals stored in the Project, which can change based on calculation of Indicators or other Panels. |
- Tags can also be used in the output of Panels based on an Excel, and in Indicators.
