Machine fuel usage (Aerius Overlay)
Template:Overlay attribute
Machine categories
Index in array Aerius Code Description
0 P1980 Pre-STAGE - 1980, 130 - 560 kW
1 P1990 Pre-STAGE 1981 - 1990, 130 - 560 kW
2 P1991 Pre-STAGE 1991 - STAGE I, 130 - 560 kW
3 S1A STAGE I, 130 – 560 kW, bouwjaar 1999/01, Cat. A
4 S1B STAGE I, 75 – 130 kW, bouwjaar 1999/01, Cat. B
5 S1C STAGE I, 37 – 75 kW, bouwjaar 1999/04, Cat. C
6 S2E STAGE II, 130 – 560 kW, bouwjaar 2002/01, Cat. E
7 S2F STAGE II, 75 – 130 kW, bouwjaar 2003/01, Cat. F
8 S2G STAGE II, 37 – 75 kW, bouwjaar 2004/01, Cat. G
9 S2D STAGE II, 18 – 37 kW, bouwjaar 2001/01, Cat. D
10 S3AH STAGE III A, 130 – 560 kW, bouwjaar 2006/01, Cat. H
11 S3AI STAGE III A, 75 – 130 kW, bouwjaar 2007/01, Cat. I
12 S3AJ STAGE III A, 37 – 75 kW, bouwjaar 2008/01, Cat. J
13 S3AK STAGE III A, 19 – 37 kW, bouwjaar 2007/01, Cat. K
14 S3BL STAGE III B, 130 – 560 kW, bouwjaar 2011/01, Cat. L
15 S3BM STAGE III B, 75 – 130 kW, bouwjaar 2012/01, Cat. M
16 S3BN STAGE III B, 56 – 75 kW, bouwjaar 2012/01, Cat. N
17 S4Q STAGE IV, 130 – 560 kW, bouwjaar 2014/01, Cat. Q
18 S4R1 STAGE IV, 75 – 130 kW, bouwjaar 2014/01, Cat. R
19 S4R2 STAGE IV, 56 – 75 kW, bouwjaar 2014/01, Cat. R
Example
We have the following fuel usages for the construction of building b.
  • 40 l / year for category: STAGE I, 130 – 560 kW, bouwjaar 1999/01, Cat. A
  • 10 l / year for category: STAGE III B, 130 – 560 kW, bouwjaar 2011/01, Cat. L
First we have to map the categories to an index:
  • STAGE I, 130 – 560 kW, bouwjaar 1999/01, Cat. A has index: 3
  • STAGE III B, 130 – 560 kW, bouwjaar 2011/01, Cat. L has index 14
The attribute for the MACHINERY_FUEL_USAGE key for building b should then be set to:
[ 0 , 0 , 0 , 40 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 10 , 0 , 0 , 0 , 0 , 0 ]
How to
