How to correct inlets on land
Revision as of 11:24, 27 May 2020 by Rudolf@tygron.nl (talk | contribs) (Created page with "Inlets are commonly pumps which allow water to flow into or out of a (water level) area. Commonly, in data these structures are modeled either as a l...")
Inlets are commonly pumps which allow water to flow into or out of a (water level) area. Commonly, in data these structures are modeled either as a line connecting two separate waterways, or as a point on land between the relevant waterways, potentially with some attribute indicating its geographical angle. For pumps this is adequate, and the data is either directly properly interpreted or automatically extrapolated. However, if the structure is at the (conceptual) edge of the relevant calculation area or project area, the structure would be modeled as an inlet or outlet, which is not treated in the same way. Likely, the centerpoint of the inlet will end up on land, rather than in the waterway it should operate on.
If the inlets cannot be placed in the waterways properly as a preperatory step, the following steps can be followed to correct the data in the Tygron Platform:
How to move inlets into the nearest waterway:
