Advanced options (New Project Wizard)
Revision as of 15:30, 24 February 2020 by Hansje@tygron.com (talk | contribs)
What are advanced options
The advanced options allow you to make a selection which data sources you want to use for your project. It varies between the option to select or deselect a data source and change some settings like the resolution of data sources.
Where to find the advanced options
Area properties based on public data pertaining the selection (default)
When choosing the location of the project area during the New project Wizard, in the second panel of the wizard, the default mode for data selection is Selection. When this option is checked, the Tygron Platform will acquire datasets from a variety of public sources that are linked to the selected area. Roads and constructions will be placed according to the available data. Find an overview on which data is loaded into the Tygron Platform on the Project Sources page. On the GEO Data page an explanation is given on the different kinds of Geo Data and how to work with your own data sources. It is also possible to use the Advanced Options in this selection location step. When you open this option the list of data sources is displayed. You can choose to include or excluded specific data sources in your location selection. For example, you can choose to import I3S data in your project. Or change the satellite background resolution.
Examples of advanced options
