Demo San Francisco Project FAQ
Revision as of 13:46, 12 February 2020 by Godelief@tygron.nl (talk | contribs) (→FAQ)
<<Previous page
FAQ
How can I change the texture, color or shape of a 3D model?
You can change the look of most 3D models manually in the editor. You can select the model you would like to change in the 3D world or from the list of present buildings, and change color and texture on the right side of the editor window. You can also change the shape of most models by using the brush functionality.
See also changing constructions. When you have used I3S data, such as shown in the Demo San Francisco project, you have to change the SLPK data file and import the data again in to hte Tygron Platform.
How do I import new 3D models?
You can upload Geo data to the Tygron Platform with the Geo Data Wizard. This way you can let the Tygron Platform generate 3D models based on your imported data. This can be done by choosing one of our 3D models for the different building type functions we have created or by uploading your own realistic model with textures. See the following page for more information Import Geo data.
How do I delete a 3D model?
You can select the model to be deleted in the 3D world or from the list of buildings. You can then select to remove the building.
See also: Removing constructions
Why do the 3D models float in the 3D world?
If imported buildings float, usually the floor/ ground level attribute is not correctly configured in the Geo data file used for the import. When the building is already generated by the Tygron Platform, the most common cause is that the building is close to an edge or other difference in terrain elevation and due to rounding off of grid cells or height sectors the building (partially) floats.
  1. How to create a new project
  2. How to use I3S data for creating a new project
  3. Video tutorial on creating a new project
  4. How to highlight data
<<Previous page
