How to access your project's WFS in ArcMap
Revision as of 14:55, 10 February 2020 by Rudolf@tygron.nl (talk | contribs)
The Tygron Platform allows you to access geographical features through a WFS endpoint, making the data available to view and edit via other GIS application.
How to access the WFS of your project in ArcMap:
- Select the export option of the geo data source you wish to access.
- For the export option "Web Feature Service", select "Copy URL". This will store the URL on your clipboard.
- Open ArcMap.
- Add a new WFS Interoperability Connection.
- Select 'WFS' as the format
- As URL for the dataset, paste the URL copied to the clipboard earlier.
- Select the Coordinate Reference System (CRS)
- In the parameters panel, select the appropriate layer in the WFS by clicking on the Feature types button and selecting the desired layer.
- In the parameters panel, for Ignore Application Schema select "Yes", and click on OK at the bottom of the panel.
- Drag the layer to your map, and the features will be displayed.
- The WFS is currently only available when a project is active in the editor.
- The WFS url includes an authentication token which ties the validity of the url to a specific session. If the editing session is closed and reopen at a later time, the url will need to be renewed.
