How to import a foliage height GeoTIFF
Revision as of 14:47, 28 November 2019 by Godelief@tygron.nl (talk | contribs) (Created page with "{{Editor steps|title=import foliage height areas in the Heat wizard |Add the Heat Stress overlay |Open the Configuration Wizard |Choose the DPRA model |Proceed and in step 3 c...")
How to import foliage height areas in the Heat wizard:
- Add the Heat Stress overlay
- Open the Configuration Wizard
- Choose the DPRA model
- Proceed and in step 3 choose Use foliage height areas
- In step 3.1 choose for the option import foliage areas (start geo data wizard).
- Click on the button Import foliage areas
- Follow the steps in the Geo data wizard. In step 6, choose the attribute name that depicts the foliage height of your features (areas).
- Finish the Geo data wizard and proceed with the Heat wizard.
- The areas that need to be imported are areas of the foliage crown along with an attribute containing the height of the trees.
- When you have chosen to import foliage height areas, there is also an option to Do nothing. Then no foliage height is used. The third option: Select existing is only for if you already have imported these areas.
For the tutorial on using the heat stress module, see:
