DPRA Heat Module
Revision as of 14:52, 12 September 2019 by Frank@tygron.nl (talk | contribs)
Each newly added Heat Overlay uses the Heat DPRA module by default. For the previously default Heat Overlay configuration, seeUNESCO Heat stress module.
The Heat DPRA module is a newl (as of 2019) heat module developed in accordance with the new Dutch DPRA standards. This module is still under revision, as is this documentation. However a Beta version of the module is available on the Preview server for our partners.
Configuration
The Heat DPRA module can be configured using the Heat Overlay configuration wizard.
For more information on the configurable model attributes, see Heat model attributes.
Results
The Heat Overlay allows user to visualize a generated Physiological Equivalent Temperature (PET) overlay, along with other intermediate overlay results. The Heat Overlay wizard allows users to select which results should be generated. For further information on the available results, see Heat Overlay result types.
Theory
The formula's and calculation models are documented here.
