DPRA Heat Module
Revision as of 13:10, 12 September 2019 by Frank@tygron.nl (talk | contribs) (Created page with "We are working on a new heat module in accordance . This module is still under construction, as is the documentation, however a Beta version of the module is available on the...")
We are working on a new heat module in accordance . This module is still under construction, as is the documentation, however a Beta version of the module is available on the Preview server for our partners.
Models
One of two calculation modules can be selected for overlay:
  • Unesco Heat stress module. This module generates a simple heat stress overlay which visualizes the PET Relative result type.
  • DPRA Heat stress module. This module is based on the new Dutch DPRA standards. It can output all available result types;
Heat is calculated in accordance to the Dutch standard for heat stress: https://ruimtelijkeadaptatie.nl/stresstest/bijsluiter/hitte/ For more detailed implementation we used RIVM-documentation: https://www.rivm.nl/bibliotheek/rapporten/2019-0008.pdf
Configuration
For the model attributes, see Heat model attributes.
Results
With a Heat Overlay, one can generate different kinds of results. For further information about these outcomes, see result types.
