Result types (Heat Overlay)
Revision as of 15:38, 10 September 2019 by Frank@tygron.nl (talk | contribs)
The Heat Module of a Heat Overlay performs complex calculations and can generate multiple types of results per timeframe. A timeframe in the Heat Overlay correspond to a date and time for which a result will be calculated. This date and time will be relative to the project's time zone.
List of Result Types
Icon | Result type | Unit | Display mode | Description |
BOWEN_RATIO | Date | |||
FOLIAGE | m | Start | ||
PET | °C | Date | ||
PET_RELATIVE | °C | Date | ||
SHADE | Date | |||
SKY_VIEW | Start | |||
SKY_VIEW_AVG | Date | |||
TEMPERATURE_ATMOSPHERE | °C | Date | ||
UHI | Date | |||
VEGETATION | Date | |||
VEGETATION_AVG | Date | |||
WIND_SPEED | m/s | Date | The wind speed measured at a weather station at the height of 10 meters above ground |
Template:Unit disclaimer (Water Overlay)
- Date: The data is dependent on the timestep, which corresponds to a date and time. In case the Average timeframe option is selected, the last timeframe will present the average values of all previous timesteps for that particular Result Type.
