Heat Reduction (Indicator)
General
What is the Heat Reduction indicator?
The Heat Reduction indicator on the Tygron platform is an indicator that computes the effect that urban green has on the heat reduction. The presence of green reduces the heat stress in the specified project area and cools down the surrounding environment. The more urban green space is present in the area, the stronger the heat reduction in that area will be. The indicator is a simplified version of a RIVM calculation model. This indicator is useful for projects where for example:
  • reducing heat stress is an important goal in the project
  • livability is measured in the project
This Excel indicator can be downloaded from the Tygron Index. Read on to find out more about the indicator's calculation method and how to set it up in your project.
Indicator panel
The heat reduction indicator
The indicator panel shows per neighborhood:
  • The name of the neighborhood
  • The percentage of urban green space in that neighborhood in the current situation
  • The percentage of urban green space in that neighborhood in the future (planned) situation
  • The temperature in that neighborhood in the current situation
  • The temperature in that neighborhood in the future (planned) situation
  • The average heat reduction in the entire project area
  • The target temperature reduction
Calculation
The calculations used in this indicator are based on the RIVM calculations on urban green and health effects[1].
Temperature = AverageTemperature x NeighborhoodArea
AverageTemperature = (GreenPercentage x 100) x HEAT_REDUCTION
GreenPercentage = GreenArea / TotalArea
Where the variables are:
  • Temperature: is the calculated temperature for the entire project area
  • AverageTemperature: is the average temperature in the selected neighborhood
  • NeighborhoodArea: is the size (m^2) of the selected neighborhood
  • GreenPercentage: is the urban green percentage of a neighborhood
  • HEAT_REDUCTION: is a global variable that indicates the percentage of heat reduction that urban green space has in the selected neighborhood
  • GreenArea: is the green effect in the core area
  • TotalArea: is the size of the entire area (m^2) specified in the project
  • CurrentGreenArea: is the size of the urban green area (m^2) in the neighborhood
  • ValidNeighborhood: is a value that indicates if the neighborhood is a valid neighborhood
Score
The score is based on the present urban green spaces in the specified project area. The effect that these urban green spaces have on the heat reduction is visible as the score of the indicator. For each neighborhood the score is based on the average temperature. For the totality of the project area, the average temperatures per neighborhood are weighed by the size of the neighborhood. In other words, the average temperature in a large neighborhood has a greater impact on the final score than that of a smaller neighborhood.
Additional configurations
Add the Attribute
Editor → Current Situation (Ribbon tab) → Current Situation (Ribbon bar) → Edit Function Values (Dropdown) → set group filter to ATTRIBUTES (Window)
A number of attributes need to be added to the project. The attribute that needs to be manually added is:
  • HEAT_GREEN: Whether this function should be counted as "green surface" for the purposes of this calculation.
These attributes can be added in the Function Values table by writing the name of the attribute in the attribute field and selecting the ‘Add’ button. The value of the newly added attributes can be adjusted for each function separately according to the needs of the project. This can be done by choosing a function, finding the HEAT_GREEN attribute in the list of attributes of that function and entering a new value in the attribute field.
Heat Reduction (Indicator):
  1. At the bottom of the function values window, enter the desired attribute name in the "Attributes" input field. Select "Add" to add the attribute to all functions.
  2. If any function has a value for the new attribute which is not 0, set it to 0.
  3. Set the attribute value of all functions which should affect this indicator to their desired values.
Add the Global
Editor → Current Situation (Ribbon tab) → Globals (Ribbon bar)
The following global variable needs to be added to the project manually:
  • Global: HEAT_REDUCTION: This global variable indicates the heat reduction per urban green space percentage in a specified area. The recommended value for this variable is 0.1.
Note that this is only an example of the values that can be entered for each of the global variables. These values can be modified and changed according to the needs of the project.
  1. Click on the add button in the bottom left corner. A new global named VARIABLE will be added to the left panel.
  2. Select the global VARIABLE.
  3. In the right panel, change VARIABLE to the name of the new global HEAT_REDUCTION.
  4. Change the start value to 0.1.
  5. Click on the tab Indicators and the button Indicators and choose for Reset to Start values (faster) to update your project.
  1. Remme, R. (RIVM), De Nijs, T. (RIVM), & Paulin, M. (RIVM). (2017)
