Function Value
Redirect page
Overview of all function values
Assets and visualisation
Function value Attribute Unit Per category Description
Image (Property of function value) Image (png, 200x100) The image used to represent this function. This property is currently unused.
Roof Color ROOF_COLOR color The color of the roof of a construction. For flat constructions (such as gardens and roads), it is also the color of the ground surface.
Ground Color GROUND_COLOR color The color of the walls of the bottom floor of a construction.
Extra Color EXTRA_COLOR color The color of the walls of the floors of the construction which are neither the top nor bottom floor.
Top Color TOP_COLOR color The color of the walls of the top floor of a construction, unless that floor is also the bottom floor.
Description (Property of function value) text The textual description of this function, which is displayed to the user when using this function as as action.
Construction
Category weight CATEGORY_WEIGHT weight Yes How much of a construction of this function is classified under the specified category.
Construction time in months CONSTRUCTION_TIME_IN_MONTHS months How long it takes to construct a construction of this function during a timeline session.
Default floors DEFAULT_FLOORS integer How many floors a construction of this function will have by default, unless otherwise specified. This values must always be in the range of min floors and max floors (inclusive).
Demolish time in months DEMOLISH_TIME_IN_MONTHS months How long it takes to demolish a construction of this functon during a timeline session.
Floating FLOATING boolean Whether this construction should be visualized with a "floating" animation, as if on water.
Floor height m FLOOR_HEIGHT_M m The height of each floor of the construction.
Max floors MAX_FLOORS integer The maximum amount of floors this construction (or any of its sections) can have. This also limits how many floors a construction can have when used as an action during a session.
Min floors MIN_FLOORS integer The minimum amount of floors this construction (or any of its sections) should have. This also limits how many floors a construction must have when used as an action during a session.
Monumental MONUMENTAL boolean Whether this construction is monumental. Projects can be set up so that monumental constructions enjoy special protections or have additional qualitative value.
Slanting roof height SLANTING_ROOF_HEIGHT m How high the slanting roof at the top of the construction should be visualized at its peak. The roof will slant inwards equally from all sides.
Unit size UNIT_SIZE_M2 m²/unit Yes How large a single housing unit within this construction is. This is only relevant for residential categories.
Zoning permit required ZONING_PERMIT_REQUIRED boolean Whether the municipal stakholder should be requested permission, when another user uses this function as an action to plan a new construction during a session
Environment
Critical infrastructure CRITICAL_INFRASTRUCTURE boolean Whether this construction counts as critical for Water Overlay calculations. Template:See also
Distance zone DISTANCE_ZONE_M m The distance drawn in the Distance Zone Overlay by this construction.
Disturbance distance DISTURBANCE_DISTANCE_M m The distance drawn in the Disturbance Distance Overlay by this construction.
Green space GREEN_M2 m²/m² The amount of green which this construction provides per m² created. Generally, this number is used along with the constructon's footprint, rather than its total floor size.
Heat effect HEAT_EFFECT decimal The effect this construction has on the Heat Overlay calculations.
Livability effect LIVABILITY_EFFECT decimal The effect this construction has on the Livability Overlay calculations.
Safety distance SAFETY_DISTANCE_M m The distance drawn in the Safety Distance Overlay by this construction.
Financial
Buyout cost BUYOUT_COST_M2 currency/m² Yes
Construction cost CONSTRUCTION_COST_M2 currency/m² Yes
Demolition cost DEMOLISH_COST_M2 currency/m² Yes
Sell price SELL_PRICE_M2 currency/m² Yes
Network
Heat flow change per year HEAT_FLOW_M2_CHANGE_PER_YEAR m²/year Yes
Heat flow formula start year HEAT_FLOW_M2_START_YEAR year Yes
Heat flow to power multiplier HEAT_POWER_TO_FLOW_MULTIPLIER factor Yes
Heat flow value at start year HEAT_FLOW_M2_START_VALUE m² Yes
Pipes permitted PIPES_PERMITTED boolean
Traffic
Height offset HEIGHT_OFFSET_M m
Lanes TRAFFIC_LANES integer
Noise sigma TRAFFIC_NOISE_SIGMA
Noise tau TRAFFIC_NOISE_TAU
Parking lots PARKING_LOTS_PER_M2 parking lot/m² Yes
Parking lots demand PARKING_LOTS_DEMAND_PER_M2 parking lot/m² Yes
Speedlimit TRAFFIC_SPEED km/h
Units per hour TRAFFIC_FLOW vehicles/h
Water
Connected top sewer area SEWERED boolean
Depth of plant roots ROOT_DEPTH_M m
Drainage DRAINAGE boolean, or m
Ground infiltration per day GROUND_INFILTRATION_MD m/day
Manning value WATER_MANNING s/(m1/3)
Water evaporation WATER_EVAPORATION_FACTOR factor
Water storage WATER_STORAGE_M2 m³/m²
(user defined) (user defined)
