Tracer ABCD (Water Overlay)
Attribute Unit Description Default
SUBSTANCE_A x/m²/s The amount of substance A created per second per m² in this location. 0
SUBSTANCE_B x/m²/s The amount of substance B created per second per m² in this location. 0
SUBSTANCE_C x/m²/s The amount of substance C created per second per m² in this location. 0
SUBSTANCE_D x/m²/s The amount of substance D created per second per m² in this location. 0
Chemical emitters/decomposers
Structures which are defined to create a negative amount of chemicals function as a scrubber or decomposer, removing the specified quantity of chemicals from the hydrological model.
In situations where water is absent, chemicals will not be moved between cells.
  • Chemical emitters must be constructions on the surface, not underground constructions.
  • Chemical emitters's attributes do not take the form of function values, and thus must be added manually or as part of loading in geodata.
  • Chemicals have generic definitions, in terms of name and magnitude, to allow for the modeling of arbitrary substances.
Template:WaterOverlay hydrological construction attribute nav
