Tracer ABCD (Water Overlay)
Attribute Unit Description Default
SUBSTANCE_A x/m²s The amount of substance A created per second per m² in this location. 0
SUBSTANCE_B x/m²s The amount of substance B created per second per m² in this location. 0
SUBSTANCE_C x/m²s The amount of substance C created per second per m² in this location. 0
SUBSTANCE_D x/m²s The amount of substance D created per second per m² in this location. 0
Chemical emitters/decomposers
Chemicals have generic definitions, in terms of name and magnitude, to allow for the modeling of arbitrary substances.
Structures which are defined to create a negative amount of chemicals function as a scrubber or decomposer, removing the specified quantity of chemicals from the hydrological model.
In situations where water is absent, chemicals will not be moved between cells.
Chemical emitters's attributes do not take the form of function values and must be added manually or as part of loading in geodata.
Template:WaterOverlay hydrological construction attribute nav
