Surface infiltration formula (Water Overlay)
First, the infiltration capacities are calculated:
Cwater = Wsurface
Ctop = max( Icon, Isurf )
Actual infiltration:
Δw = min( Cwater , Δt * Ctop)
Where:
  • Ctop = The amount of infiltration that can take place based on the infiltration values present.
Template:WaterOverlay nav
