Water Module getting started
Revision as of 09:57, 13 May 2019 by Hedi@tygron.com (talk | contribs)
There are several approaches for getting started with the Water Module:
- If you would like to get familiar with the different components of the Water Module first, check out the Water Module Testbed. This Testbed is available to you as a project in the Tygron Platform.
- If you want start by practising with the basics of the Water Module in a theoretical setting, follow the Testbed Tutorial.
- If you want start by practising with the basics of the Water Module in a real situation, follow the Rainfall Overlay Tutorial
- If you prefer to get started with setting up the water model in a project area of your own choice, follow the steps in the Basic Water Model Use Case.
Also See
Getting started with the Tygron Platform.
