UK Benchmark 6 (Water Module)
The Benchmark of the UK Environmental Agency (EA, 2013) is used to assess the functioning of the numerical scheme for several cases. The results are described below.
Benchmark 3
description
Tygron Platform version: 2019.0.0 DEV 68.0
Date executed: 2018-07-11
Characteristics: Test for conservation of momentum over a small obstruction. By inertia (flow changing over time) some water flows over the obstruction.
  • Dimensies: zie Figuur below
  • Roughness: uniform manning = 0,01 m/s1/3
  • Initial condition: 0m water depth
  • Resolution: 5m grid
  • Boundary condition: Q(t), see figure below
File:Inundation benchmark 05.PNG
results
Results every 2 seconds in the middle of every despression are requested and shown below
File:Inundation benchmark 06.PNG
Benchmark 6
description
Tygron Platform version: 2019.0.0 DEV 61.0 Date executed: 2018-07-09
Characteristics:
  • Dimensions: 20X the values below
  • Roughness: uniform manning = 0,05 m/s1/3
  • Initiële conditions: 8m in reservoir, 0,4m in floodplain
  • Modelgrid resolution: 2m
results
Waterlevels and profiles at the locations indicated in figure above
Velocity profiles
  1. Environmetal Agency (2013). Benchmarking the latest generation of 2D hydraulic modelling packages ∙ report Report – SC120002 ∙ found at: https://consult.environment-agency.gov.uk/engagement/bostonbarriertwao/results/appendix-6---neelz--s.---pender--g.--2013--benchmarking-the-latest-generation-of-2d-hydraulic-modelling-packages.-bristol_environment-agency.pdf (last visited 2018-08-03)
