Infiltration model (Water Overlay)
Revision as of 14:44, 12 April 2019 by Frank@tygron.nl (talk | contribs)
The Water Module supports two types of infiltration; surface to unsaturated zone and unsaturated to saturated zone. Furthermore, exfiltration can also occur due to horizontal groundwater flow.
Infiltration
File:Infiltration model.png
When water infiltrates from the surface, it infiltrates at a speed dictated by the surface terrain's GROUND_INFILTRATION_MD attribute, the underground terrain's GROUND_INFILTRATION_MD attribute, or (if present) by the construction's GROUND_INFILTRATION_MD, whichever value is lowest. The least porous material present will always serve as a bottleneck for the water to flow through, even if the other layers allow for a high rate of infiltration.
Exfiltration
