Inundation area (Water Overlay)
Revision as of 12:57, 4 April 2019 by Frank@tygron.nl (talk | contribs) (Created page with "An inundation is an initial placement of a quantity of water. This differs from the {{inlink|lcase=1|Water level area}}s in that an inundation level allows you to place water...")
Template:Overlay attribute
  • If a grid cell is not covered by an inundation area or it is marked as water, the grid cell will not be inundated.
  • For terrain with a steep decline, using a single inundation area to define the inundation level might not suffice, since the level is a datum height, not a relative offset from the bottom.
Template:WaterOverlay object nav
