Sewer overflow (Water Overlay)
Revision as of 16:37, 3 April 2019 by Frank@tygron.nl (talk | contribs) (Created page with "Sewer overflows are points where water is moved from the sewer area to the above-ground water system. A sewer overflow will allow water to flow through if the water in the sew...")
A sewer overflow is a point-based constructions. It must intersect with a sewer area, but does not need to intersect with an actual sewer. {{Overlay attribute |attributeSEWER_OVERFLOW |unit=m + datum |description=The height of the bottom of the sewer, relative to the average terrain height of the connected sewer. Starting from this height, the water height in the sewer must exceed the height of the terrain at the location of the overflow in order for water to flow out. |defaultvalue=n/a |icon=Waterwizard icon sewer overflow height.png |attribute2=SEWER_OVERFLOW_SPEED |unit2=m3/s |description2=The maximum speed at which water can flow out from the sewer through this overflow. |defaultvalue2=10 |icon=Waterwizard icon sewer overflow speed.png |} Note that at most one overflow can exist per sewer area.
