Pump (Water Overlay)
Pumps are constructions which can move water against its natural flow. Specifically, a pump with a positive pump speed will pump water from the entry point with the lowest initial water level to the entry point with the highest water level. If no water level is defined for an entry point, the surface height is taken.
A pump is a line-based constructions. Template:Overlay attribute
  • A negative value for the PUMP_Q attribute is also allowed, in which case water can be pumped in the reverse direction.
