Pump (Water Overlay)
Waterwizard icon pump q.png A pump is a line-based constructions. Template:Overlay attribute
  • A pump with a positive PUMP_Q attribute will pump water from the entry point with the lowest initial water level to the entry point with the highest water level. If no water level is defined for an entry point, the surface height is taken. A negative value for the PUMP_Q attribute is also allowed, in which case water can be pumped in the reverse direction.
