Weir (Water Overlay)
Revision as of 16:10, 3 April 2019 by Frank@tygron.nl (talk | contribs) (Created page with "Weirs are effectively small dams in the water, and allow water to flow from a water body with a higher water level to a lower water level. Any water exceeding the height of th...")
A weir is a line-based constructions. Template:Overlay attribute |unit=m + datum |description=The height of the weir. |defaultvalue=n/a |icon= |- |attribute2=WEIR_WIDTH}} |unit2=m |description2=The width of the weir. |defaultvalue2=5 |icon2= |- |attribute3=WEIR_COEFFICIENT}} |unit3=coefficient |description3=The flow coefficient related to the shape of the weir. |defaultvalue3=1,1 |icon3= |}
