Terrain ground infiltration md (Water Overlay)
Revision as of 13:18, 3 April 2019 by Frank@tygron.nl (talk | contribs)
Template:Overlay terrain attribute
Infiltration and storage
Underground flow, or horizontal infiltration, are dependent on the infiltration properties of the underground, unless an aquifer exists the same location.
- The groundwater level reduction is inversely proportional to the WATER_STORAGE_PERCENTAGE, as the contribution of a given volume of water to the groundwater level increases when the capacity for water storage in the underground layer decreases.
