Terrain ground infiltration md (Water Overlay)
Revision as of 11:43, 3 April 2019 by Frank@tygron.nl (talk | contribs) (Created page with "{| class="wikitable" ! Attribute ! Unit ! Terrain type ! Description |- |{{anchor|GROUND_INFILTRATION_MD_surface|GROUND_INFILTRATION_MD}} |m/day |Surface |The speed at which w...")
| WATER_STORAGE_PERCENTAGE | fraction | Underground | The percentage of the underground volume which can be filled with water. A lower percentage means the underground will be able to store less water, and the saturated zone will rise higher with the same amount of water in the underground layer. |
Infiltration and storage
Underground flow, or horizontal infiltration, are dependent on the infiltration properties of the underground, unless an aquifer exists the same location.
- The groundwater level reduction is inversely proportional to the WATER_STORAGE_PERCENTAGE, as the contribution of a given volume of water to the groundwater level increases when the capacity for water storage in the underground layer decreases.
