Water manning (Water Overlay)
Revision as of 10:07, 3 April 2019 by Frank@tygron.nl (talk | contribs) (Created page with " {{Overlay attribute |WATER_MANNING |s/(m<sup>1/3</sup>) |Surface |The Gauckler–Manning coefficient of the construction. }} ====Manning value (construction)==== Construction...")
Template:Overlay attribute
Constructions have an inherent "roughness", which influences how fast water can flow across the surface. This is known as the Manning coefficient or Manning value.
  • If no construction is present in any location, the WATER_MANNING value of the surface terrain present is used instead.
Template:WaterOverlay attribute nav
