Pump formula (Water Overlay)
Revision as of 13:21, 2 April 2019 by Frank@tygron.nl (talk | contribs) (Created page with "The flow created by a pump is calculated based on the lowest end point of the pump. : ''Δw = min( WH<sub>lower</sub> , Δt * PS )'' Where: * Δw = The amount water water pu...")
Δw = min( WHlower , Δt * PS )
Where:
  • WHlower = The height of the water column at the lower end of the pump, relative to the terrain.
Template:WaterOverlay nav
