Timestep formula (Water Overlay)
Revision as of 12:43, 2 April 2019 by Frank@tygron.nl (talk | contribs) (Created page with "An adaptive timestep is implemented according to Kurganov and Petrova (2007)<ref name="Kurganov1" />. At every timestep, the courant-number is kept smaller than 0.25 for every...")
Template:WaterOverlay nav
  1. 1.0 1.1 Cite error: Invalid <ref> tag; no text was provided for refs named Kurganov1
