Version 2019.3.0
Revision as of 17:40, 12 December 2018 by Maxim@tygron.com (talk | contribs) (Created page with "Version 2019.3.0 is released on preview.tygron.com (Preview) on Wednesday Dec 19th 2018 '''Water''' * Outlets are now correctly named Inlet (positive values). * A negative va...")
Water
  • Outlets are now correctly named Inlet (positive values).
  • A negative value for inlet behaves as an outlet.
  • Performance improvement for ground water.
  • New option to set both min and max target levels on Water Areas that trigger and in/outlet to become active.
Interface
  • Renamed Dike to Levee.
  • Bugfixes for Measurement Tool.
  • Measurement Tool shows distance in meters and had start/end color dots.
  • Measurement Tool flies to old location when selecting a previous Measurement.
SDK
  • Removed all JavaFX code from Developer SDK, Java 11 compatible now.
