Water Overlay
What are the Water Overlays
Configuration Wizard
File:Config wizard.JPG
Step 1
Step 2
- ground water data
- Weirs
- Culverts
- Pumps
Step 3
Step 4
Step 5
Step 6
Hydrological constructions
The water system can be enhanced with a number of hydrological constructions. These are constructions which form direct connections between exact locations in water bodies, allowing water to flow from one point to another according to the parameters and rules of the constructions used.
Water can flow into and through the constructions as soon as their height (if any) is reached. Exact details of this behavior differ between constructions. Flow through hydrological constructions is instantaneous. The two endpoints of the construction are treated as adjacent cells.
Culvert
| CULVERT_HEIGHT | mNAP | The height of the culvert. (When set to -100000, the culvert's endpoints are at the height of the terrain in that location.) | 0 |
Weir
| WEIR_HEIGHT | mNAP | The height of the weir. | n/a |
Pump
Pumps are constructions which move water against its natural flow. It moves water from the water body with the lower water level to a higher water level.
| PUMP_SPEED | m3/s | The speed at which water is pumped from the lower water level to the higher water level. | n/a |
Sewer overflow
Sewer overflows are points where water is moved from the sewer area to the above-ground water system.
| SEWER_OVERFLOW | mNAP | The height of the crest of the sewer overflow. The water level in the sewer must exceed this height before it flows out into the above-ground water system. | n/a |
| SEWER_OVERFLOW_SPEED | m3/s | The speed at which water is pumped from the lower water level to the higher water level. | 10 |
Result types
Each Water Overlay is a grid overlay showing results on the surface (flooding), sub-surface (groundwater), open water and sewer system. The following results are produced:
| Result type | Unit | Description |
| BASE_TYPES | nominal value | Division of gridcells in water, land, water level areas, sewer areas that are connected to the sewer, breach areas and hydrological constructions |
| CHLORIDE | Description will be added when available | |
| DIRECTION | Degrees | The direction of the flooding |
| EVAPORATED | m (mm)¹ | The amount of water that is evaporated |
| GPU OVERVIEW | nominal value | Shows which GPU cluster calculated which part of the overlay |
| IMPACTED_BUILDINGS | nominal value | Constructions impacted by flood: the value from the function value indicator is assigned to a building if the water depth at a grid-cell surrounding the building exceeds the overlay attribute value IMPACT_FLOOD_TRESHOLD_M |
| LAST SPEED | m/s | The speed of the flooding at the last calculated timestep |
| MAX SPEED | m/s | The maximum speed of the flooding of all the calculated timesteps |
| NITROGEN | Description will be added when available | |
| PHOSPHORUS | Description will be added when available | |
| SEWER_LAST_VALUE | m (mm)¹ | The amount of water in the sewer storage at the last calculated timestep |
| SEWER_MAX_VALUE | m (mm)¹ | The maximum amount of water in the sewer storage of all the calculated timesteps |
| SURFACE_DURATION | s (min)¹ | The amount of time the water depth in a cell exceeds the value set in the overlay attribute value SHOW_DURATION_FLOOD_LEVEL_M |
| SURFACE_FLOW | m3/m2 | Total volume of water passed a grid-cell, scaled by the cell surface (grid cell-size^2) |
| SURFACE_LAST_VALUE | m (mm)¹ | The water depth at the last calculated timestep |
| SURFACE_MAX_VALUE | m (mm)¹ | The maximum water depth of all the calculated timesteps |
| UNDERGROUND_FLOW | m³/m² | Total infiltration amount from the surface to groundwater |
| UNDERGROUND_LAST_STORAGE | Description will be added when available | |
| UNDERGROUND_LAST_VALUE | m (mm)¹ | The amount by which the groundwater table has risen above the initial groundwater level at the last calculated timestep |
| UNDERGROUND_MAX_STORAGE | Description will be added when available | |
| UNDERGROUND_MAX_VALUE | m (mm)¹ | The maximum amount by which the groundwater table has risen above the initial groundwater of all the calculated timesteps |
| UNDERGROUND WATERTABLE | Description will be added when available | |
| WATER_STRESS | m (mm)¹ | The maximum water depth of all the calculated timesteps (almost the same as the SURFACE_MAX_VALUE, but if the terrain type is water only a water depth is shown if the depth exceeds the overlay attribute value ALLOWED_WATER_INCREASE_M) |
General Tab
Calculation Preference
Δt = Δx /umax
- Δt = computational timestep
- Δx = grid cell size
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
- Water areas:
Keys tab
| Breach Floor | mNAP | Modified terrain height, to simulate a breach in a levee. |
| Inundation level | mNAP | Initial water height, to simulate water present at the start of the simulation. |
Attributes tab
| ALLOWED_WATER_INCREASE_M | m | increment by which the water level on a water cell is allowed to increase before the depth is shown in the WATER_STRESS result type |
| AVG_SURFACE_WATER | Description wil be added | |
| DESIGN_FLOOD_ELEVATION_M | m | Description wil be added |
| GROUND_BOTTOM_DISTANCE_M | m | Description wil be added |
| GROUND_WATER | Description wil be added | |
| IMPACT_FLOOD_THRESHOLD_M | m | maximum waterdepth on a cell which touches the building where after the building is assumed impacted, visualized in the IMPACTED_BUILDINGS result type |
| MAX_SPEED_MS | Maximum speed at which water is allowed to flow. As the maximum speed is set higher, the time per step of the calculation is reduced, increasing total time for the calculation to complete. | |
| MIN_SLOPE | slope whereunder the pressure slope is assumed 0 | |
| SEWER_OVERFLOW_THRESHOLD | fraction of storage whereafter sewer overflows take place | |
| SHOW_DURATION_FLOOD_LEVEL_M | m | threshold value of the amount of water on a grid cell that is used for the SURFACE_DURATION result type |
| SUPERGRID | Description wil be added | |
| SURFACE_WATER_EVAPORATION_FACTOR | Description wil be added | |
| TIMEFRAMES | the number of intermediate (overlay) results you would like to see of the calculation. A timeframe is not the same as a timestep. A timeframe is an intermediate (overlay) result and can contain already a number of timesteps. The number of timesteps is based on the grid cell size and the speed of the flooding (see for more information the Courant number). |
