Attribute Overlay
This article is a stub.
What the Average overlay is
File:Attribute overlay example.JPG
The attribute overlay, displaying buildings with traffic flow.
The attribute overlay is an overlay which displays the presence of a specific attribute in a data layer. A data type, such as buildings, neighborhoods, or areas, is checked. If the data has the specified attribute, it is highlighted in the 3D world by the overlay.
The hover panel of the attribute overlay displaying building data.
When a specific (highlighted) location in the 3D world is clicked, the hover panel can display additional information on the underlying data. The name of the data item being highlighted is displayed, as well as the value of the attribute based on which it is being highlighted. For example, if buildings are highlighted with the TRAFFIC_FLOW, it will display the name of the building, some information on its size, and the TRAFFIC_FLOW value.
Purpose of the Attribute Overlay
The primary purpose of the attribute overlay is to highlight data with a specific attribute. This allows for simple, slightly dynamic visualizations of data such as:
  • Buildings with traffic data.
  • Zones with building height restrictions.
The overlay can be further enhanced with some in-software calculations or external processing. By calculating the desired color which should be used to display data (either using excels and TQL statements, or by preprocessing data in an external program and then loading the results in your project), it's possible to differentiate data in the map using multiple colors. This can allow you to visualize data such as:
  • The ages of constructions.
  • The types of buildings in the world.
  • Self-calculated scores for areas or neighborhoods
For more information on how to realize the more dynamic use-cases, check the articles on Excel, TQL, the Geo Data Wizard, and color attributes.
Configuring the overlay
The Right Panel when an attribute overlay is selected.
By default, the overlay does not display any relevant information. The properties of this overlay must be configured first, most notably the attribute based on which to highlight data.
Name
The field for the "name".
The name of the overlay. This is the name that will appear as the title overlay, when hovering over the related icon in the minimap. It is also the text in the legend of the overlay as description for the overlay. You can change this by altering the text in the "Name" field.
Attribute color and Background Color
The fields for the "Attribute Color" and "Background Color".
The colors of the overlay. The "Attribute Color" is the color used to indicate the data with the specified attribute in the 3D world. Note that this will be overwritten if a color attribute is set. The "Background Color" is the color used to color all other areas. You can toggle this on or off with the checkbox. You can change both colors by selecting the color field. A panel will appear in which you can specify the desired color.
Type
The selection dropdown for data type.
The data type which should be checked by the overlay. The type of data you wish to highlight must be explicitly selected. You can change the data type by selecting a different type in the dropdown menu.
Filter Attribute
The attribute which should be highlighted by the overlay.
Color Attribute
The attribute which defines the color to be used to highlight this data.
If set, this attribute is used to determine the color with which to highlight the data. This allows for a more detailed overview of the highlighted data.
Create an Attribute Overlay
Template:Editor ribbon
How to add the Attribute overlay:
  2. Select 'Overlays' from the ribbon bar
  3. Select the 'Add Attribute' overlay
  4. XXX
Selection type
Select attribute value
Select Layer
Attributes can be assigned to one of more layers in the 3D model: Buildings, Terrains, Areas and Neighborhoods. In this step you can select the following options for choosing which attribute values you would like to see:
  • Filter occurrence in Layers: an attribute value is selected from order of occurrence in the model data layers mentioned above
  • Minimum values in Layers. The minimum value is selected from all layers above
  • Maximum values in Layers. The maximum value is selected from all layers above
  • Specific Layer only. A specific layer can be selected.
How to remove the Average overlay:
  3. Select the desired overlay from the list of active overlays on the left panel
  4. Select 'remove' from the bottom of the left panel
  5. Confirm the removal in the pop up confirmation message
