Left Panel
Revision as of 09:00, 17 August 2018 by Rudolf@tygron.nl (talk | contribs)
How does the left panel relate to the Tygron Platform
The left panel, on the left side of the screen, provides access to sub-items and functionality of the item currently selected on the ribbon bar. For example, when the indicators button is currently selected on the ribbon bar, access to the current active indicators in the project is available.
The Tygron Editor. The Ribbon at the top of the screen, the Left Panel on the left side of the screen, the User Main Interface in the center of the screen, the Right Panel on the right side of the screen, and the Bottom Panel at the bottom of the screen.
Left panel overview
The left panel allows you to select, add and remove items.
This example shows the left panel when the indicators button is selected in the ribbon
File:Editor left panel search.jpg
The search field.
The left panel starts with a search field, useful for lists with a lot of items.
Show only for...
File:Editor left panel showonly.jpg
Show only for....
In some Panels a checkbox "Show only for..." is available. Checking this checkbox only displays the options available to the currently selected stakeholder. Unchecking this checkbox displays all options available to all stakeholders.
Items
Item-list
The left panel features different context-senstitive items. Selecting one of the items makes the properties available of the selected item. Its properties can be adjusted in the right panel.
Adding and removing Items
Adding, Removing and duplicating Items
The bottom of the left panel provides access to adding and removing items (in this case indicators).
