Heat Stress Overlay
What the heat overlay is
File:Editor overlay heatstress.jpg
Active heat stress overlay
The heat stress overlay is an Overlay which displays the average temperature deviation (positive or negative) in different colors for the project area, indicating transitions in temperatures, resulting in heat stress. The default colors of the overlay generally mean the following:
Color: Blue
Blue indicates the coolest area's, compared to the surroundings.
Color: Green
Green indicate cool area's, compared to the surroundings.
Color: Yellow
Yellow indicates warmer area's, compared to the surroundings.
Color: Red
Red indicates the hottest area's, compared to the surroundings.
It is possible to change the colors of the overlay by editing the Legend.
File:Editor overlay heat stress hover.jpg
Hover panel displays additional information
The hover panel gives additional information when the overlay is active.
Surrounding Heatstress
The amount of heat stress from the surroundings in °C.
Calculation Model
Because the Heat Overlay is directly linked to the Heat Stress indicator, it is currently not possible to load this Heat overlay separately. To activate the Heat overlay in you project, please see the documentation about Adding/removing indicators.
Adding and removing
Template:Editor ribbon
How to add the Heat stress overlay:
  2. Select 'Overlays' from the ribbon bar
  3. Select the Heat stress overlay from the drop down menu
How to remove the Heat stress overlay:
  3. Select the desired overlay from the list of active overlays on the left panel
  4. Select 'remove' from the bottom of the left panel
  5. Confirm the removal in the pop up confirmation message
