Template Project
What is a template in the Tygron Engine
A template is a project that can be used to create a new project with. This new project can have a different location as the original template project, but has the same Indicators, Actions, Overlays settings etc. as the template project. This is very convenient in case a similar spatial issue is at hand on different locations and you want to create different projects for these locations. Also, this functionality enables the user to make elaborate predefined actions or custom indicators, which can then be easily transposed with a template to another area. This functionality saves a lot of time and makes preparing projects faster.
What is transferred to a new project
In a template project, certain elements are transferred to a new project, created with the template. These elements are the elements that are not spatial, thus the elements that are not linked to a location. These are for example:
- Indicators
- Overlays
- Stakeholders
- Panels (the location of the panels must be set)
- New functions/changes in function values
- Globals
- Actions
- New/changed Upgrade types
- WFS connections in the Geo Data Wizard
Elements that are not transferred to a new project are for example:
- (Imported) Areas. The areas have a certain location in the template project. The new project is very likely on a new location and therefore the areas are not in that location and in the new project
- Measures. Measures are drawn on a certain location, this location is also not present in the new project anymore
- Cinematics. In a cinematic, the camera has a certain location in the 3D world, since the location is different in the new project, the cinematic will not be trasnferred.
Default templates in the Tygron Engine
There are multiple default templates available in the Tygron Engine, including Climategame. For more information about this specific template, see the page for the Climategame.
How to create a template project
To create a template project, start with a project that you want to use as a template for other projects. In the template settins screen, the data sources that should be used by default when using this template, can be set. For example AHN3 can be selected so that the AHN3 is always used when creating a project based on the template.
The clear map option is a permanent setting. Even if the project is not saved, the map is still cleared. Therefore it is recommended to create a new version first, or to make a copy of your project by saving the project under a different name.
- Start with a project you want to use as a template
- Create a new version of your project
- Go in the Editor Ribbon to Tools --> Template --> Template settings.
- Set the desired data sources for new projects based on this template
- Clear map. Warning: this will remove the 3D world from your project and can not be undone
- Save the project under a new name so as to create a new project
- Log in with Domain Admin rights
- Select "Options"
- Select "Projects"
- Highlight project to be made a template
- Check box named "Template (project becomes read only)"
How to add your own template
- Projects can easily be set as a template, to be used as base for next projects. Once a project has been set as template it is added to the list of available templates. Setting a project as a template can only be done by users with Domain Administrator rights. By default the template is not shared with other users within your domain. Please refer to the next paragraph about making templates available for the domain.
- Setting a project as a template makes the project read only!
- Select "Options"
- Select "Projects"
Sharing your template with other users in your domain
- When a project has been made a project template, the read and write permissions will change. This is to ensure that nobody accidentally edits the project template. No write permissions remain (project cannot be edited anymore) and only the creator can read the template by default. In order to change the read permissions, so that other users within the same domain can also use the template, the creator can change the permissions of the original project in the editor.
- Load in the editor the template project to be shared with the domain
- Select "File" when in main view
- Select "Permissions"
- Change the entry for "Other users in domain" to "Read"
- Save project
