Underground infiltration formula (Water Overlay)
Jump to: navigation, search
S = Wunsat/Hunsat
Finally, calculate the actual amount of water infiltrating.
Δw = Cinf * S
Where:
Related
Groundwater level formula
Surface infiltration formula
Models
Underground model
Infiltration model
Substance flow model
