Api logs
Revision as of 13:33, 23 November 2026 by Server@tygron.com (talk | contribs) (Created page with "API Base URL: api/logs/ ===GET logs=== API Endpoint: api/logs/ '''Parameters:''' None ===GET {type}=== API Endpoint: api/logs/{type} '''Parameters:''' {|class=wikitable !Name !Location !Type !Default value |- | type | Path | String | |- | latest | Query | boolean | false |- | priority | Query | Priority | |} ===GET {token}=== API Endpoint: api/logs/{type}/{token} '''Parameters:''' {|class=wikitable !Name !Location !Type !Default value |- | type | Path | String |...")
GET logs
Parameters: None
GET {type}
Parameters:
Name Location Type Default value
type Path String
latest Query boolean false
priority Query Priority
GET {token}
Parameters:
type Path String
token Path String
