Web terrain
API Base URL: web/terrain
GET txt
API Endpoint: web/terrain.txt
Parameters:
| Name | Location | Type | Default value |
| format | Path | String | |
| bbox | Query | String | |
| crs | Query | String | EPSG:3857 |
| id | Query | Integer | |
| maptype | Query | Map Type | MAQUETTE |
| width | Query | int | 256 |
| height | Query | int | 256 |
| offset | Query | float | 0 |
| worlddatum | Query | boolean | false |
| decimation | Query | int | 16 |
Examples
Basic Query:
https://engine.tygron.com/web/terrain.txt?&token=WEB_TOKENQuery with BBOX (EPSG:3857):
https://engine.tygron.com/web/terrain.txt?&crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=WEB_TOKENQuery with width=16 and height=16:
https://engine.tygron.com/web/terrain.txt?width=16&height=16&token=WEB_TOKENQuery for MapType: CURRENT:
https://engine.tygron.com/web/terrain.txt?maptype=CURRENT&token=WEB_TOKENQuery with World instead of CRS Datum:
https://engine.tygron.com/web/terrain.txt?worlddatum=true&token=WEB_TOKENGET txt
API Endpoint: web/terrain/{z}/{x}/{y}.txt
Parameters:
| z | Path | int | |
| x | Path | int | |
| y | Path | int | |
| v | Query | String | |
Examples
Query Tiling endpoint: /terrain/{z}/{x}/{y}.txt:
https://engine.tygron.com/web/terrain/3/2/1.txt?token=WEB_TOKENGET bin
API Endpoint: web/terrain/{z}/{x}/{y}.bin
Parameters:
| z | Path | int | |
| x | Path | int | |
| y | Path | int | |
Examples
Terrain Tiles (elevation):
https://engine.tygron.com/web/terrain/3/2/1.bin?token=WEB_TOKEN
