Api event user set domain adress info
API Endpoint: api/event/user/set_domain_adress_info/
Description: Update the Domain contact information.
| 0 | OPTIONAL | (String) | Domain Name (optional, leave empty by default) | |
| 1 | REQUIRED | (String) | Address | |
| 2 | REQUIRED | (String) | Zip Code | |
| 3 | REQUIRED | (String) | City | |
| 4 | REQUIRED | (String) | Country |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/event/user/set_domain_adress_info/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "", "Addres", "Zipcode", "City", "Country" ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: '[ "", "Addres", "Zipcode", "City", "Country" ]'
fetch("https://engine.tygron.com/api/event/user/set_domain_adress_info/", options)
