Api event user get my login key
Revision as of 15:18, 20 November 2026 by Server@tygron.com (talk | contribs)
API Endpoint: api/event/user/get_my_login_key/
Description: Get your login key for continued authentication.
200 String (String)
curl 'https://engine.tygron.com/api/event/user/get_my_login_key/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d ''
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: ''
fetch("https://engine.tygron.com/api/event/user/get_my_login_key/", options)
