Api event io set project trashed
Revision as of 15:17, 20 November 2026 by Server@tygron.com (talk | contribs)
API Endpoint: api/event/io/set_project_trashed/
Description: Mark project as trashed, to be deleted later.
0 REQUIRED (String) Project Name
1 REQUIRED (true, false) Trashed true or false
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/io/set_project_trashed/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Project Name", true ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "Project Name", true ]'
fetch("https://engine.tygron.com/api/event/io/set_project_trashed/", options)
