Api event io set project sub domain
API Endpoint: api/event/io/set_project_sub_domain/
Description: Set a Project to be available to a sub Domain of the Domain the Project is currently in. A Subdomain can only access this Project if this property matches the name of the Subdomain exactly.
| 0 | REQUIRED | (String) | Project Name | |
| 1 | REQUIRED | (String) | Subdomain name |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/event/io/set_project_sub_domain/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Project Name", "Subdomain name" ]'JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: '[ "Project Name", "Subdomain name" ]'
fetch("https://engine.tygron.com/api/event/io/set_project_sub_domain/", options)
