Api event io set project owner
Revision as of 15:17, 20 November 2026 by Server@tygron.com (talk | contribs)
API Endpoint: api/event/io/set_project_owner/
Description: Change the owner of a Project.
0 REQUIRED (String) Project Name
1 REQUIRED (String) New owner
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/io/set_project_owner/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Project Name", "New owner" ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "Project Name", "New owner" ]'
fetch("https://engine.tygron.com/api/event/io/set_project_owner/", options)
