Api event io set project active version
Revision as of 15:17, 20 November 2026 by Server@tygron.com (talk | contribs)
API Endpoint: api/event/io/set_project_active_version/
Description: Set which version of a Project is the currently active version. A Project cannot be running when the version is changed.
0 REQUIRED (String) Project Name
1 REQUIRED (Integer number) Version of the Project
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/event/io/set_project_active_version/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d '[ "Project Name", 1 ]'
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: '[ "Project Name", 1 ]'
fetch("https://engine.tygron.com/api/event/io/set_project_active_version/", options)
