Api event io get startable templates
API Endpoint: api/event/io/get_startable_templates/
Description: Get all Projects in the Domain which can be used as a template.
| 200 | ProjectData[] (ProjectData array) |
curl 'https://engine.tygron.com/api/event/io/get_startable_templates/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d ''JavaScript example POST
headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
body: ''
fetch("https://engine.tygron.com/api/event/io/get_startable_templates/", options)
