Api event io get server time
Revision as of 15:17, 20 November 2026 by Server@tygron.com (talk | contribs)
API Endpoint: api/event/io/get_server_time/
Description: Get the current server Time in milliseconds, useful for synchronizing client-server clocks.
200 Long (Current server time in milliseconds since epoch 1970)
curl 'https://engine.tygron.com/api/event/io/get_server_time/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d ''
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: ''
fetch("https://engine.tygron.com/api/event/io/get_server_time/", options)
