Api event io get domain usage
Revision as of 15:17, 20 November 2026 by Server@tygron.com (talk | contribs)
API Endpoint: api/event/io/get_domain_usage/
Description: Get the License usage for a given domain.
0 OPTIONAL (String) Domain Name (optional, leave empty by default)
1 OPTIONAL (String) Subdomain Name (optional)
200 Integer[] (Returns an array with: New Projects per day, Project count, Domain Total Area (km2), Subdomain Total Area (km2), GeoShare storage (MB) and Total Archive (km2).)
curl 'https://engine.tygron.com/api/event/io/get_domain_usage/' -H 'Content-Type: application/json' -H 'Authorization: Basic <credentials>' -d ''
JavaScript example POST
 headers: { "Content-Type": "application/json", "Authorization": "Basic <credentials>" },
 body: ''
fetch("https://engine.tygron.com/api/event/io/get_domain_usage/", options)
